When I open Reaper audio production software I get an error as shown below. I am a novice of this software and am stuck without an idea of what to do. Please help.
Missing plugins
The following plugins could not be found or failed to open.
S01: VST. VB_ffx4
S02: VST. VB_ffx4
Reaper audio production software getting an error
Try remembering first if your operating system made an update in the past few days before the problem started. If it does then the problem may have been triggered by the recent update of Microsoft Windows. Try restoring your computer to the period before the update was made then try running the program again.
If you didn’t touch anything in the files of the application where you might have accidentally deleted some files without you noticing it, you may try reinstalling it. Uninstall it first then install it again. If this didn’t fix the problem, uninstall it again then restart your computer. Open Windows Explorer then navigate to “C:Program Files”.
Delete Reaper’s folder if uninstalling it didn’t remove the directory. After that open your web browser then visit Reaper Digital Audio Workstation to download Reaper 4.54, the latest version. Run the newly downloaded installer after the download to install it then check if this version will work.
