Reaper Audio production software works with many plug-ins. Whenever I try to add a plug-in or open the plug-ins already available, I get an error message stating “This host does not support plugins changing their output configuration.”
Reaper
Reaper Audio production software plugin error
This message you see after opening a plug-in doesn’t really mean that there is already something wrong with the program. This may mean that the plug-in you accessed doesn’t allow its configuration to be changed. If you want a plug-in that is modifiable, install a plug-in that allows its configuration to be changed.
There are several plug-ins you can install along with your version of Reaper. One plug-in you can try is ReaPlugs VST. It will let you use some of the comprehensive FX plug-ins provided by Reaper. To download, visit ReaPlugs VST FX Suite. This is an FX package that contains various plug-ins that comes with Reaper. See image.
You may also try visiting Antress Modern Plugins. It includes a general edition of powerful signal processor good for general mixing, modern compressor, modern equalizer, modern expander, modern exciter, modern De-Esser, modern limiter, modern spacer, and more. Another one is Bootsy from Variety of Sound. Some of the latest VST plug-ins you can download are BootEQ mkII, Density mkIII, Rescue MK2, TesslaSE, TesslaPRO mkII, epicVerb, and more.
