I recently installed TNT software for server monitoring and Windows event log management. I want to improve system performance while still having full access to online contents. What are some possible scenarios when TNT locks online content for Windows Server?
Reason behind TNT locks online content for Windows Server
Hi Holden,
Windows Event Log is a useful source of information control, telling the story of the problems and issues that may be present on the server. The problem with the Windows event log, however, the focus is on the server to store registration information. Store registration information for this server only makes it difficult to get a comprehensive view of network problems. If there was a problem arises between two servers that are used to control a particular network service, you need to trawl through the records of these two events separately for information about the problem.
Thanks
Patrick Opal
Hi Holden,
You want to improve your system performance so you should to lock some of extra contents for Windows Server and you can do this step easily first you are going to your TNT software configuration setting there are many tabs so you should to go setting option and there you can lock contents easily Hopefully this instruction will help you.
Thanks
Raun Nelson
