Reason For My Outlook Is Not Responding And Its Easy Solutions.
Hello, my outlook is not responding so what all be the reason for not working kindly notify in detail for the easy going of it. Thank you in advance.
Hey, if my outlook is not responding then kindly follows the below steps to get the solution for the same are as follows:
• First look for the outlook.exe file over your system.
• The file can be found in the C drive> Microsoft office > root> office16
• Now right click to the .exe file and then chose for properties > compatibility.
• In the compatibility tab if there’s any checked boxes do uncheck them and then go for apply > Ok
• Now restart the outlook to get its effects successfully
