Reboot and battery issue with ASUS TF101
Since my upgrade to Android Ice Cream Sandwich version 4.0.3, I am facing problems with constant reboots on my ASUS TF101.
The battery backup has fallen after I have updated. Is this a common issue with the new Android upgrade?
Answered By 590495 points N/A #153602
This is usually the common side effect of upgrading the mobile phone’s operating system. There are times that the expected outcome of the process is not the one to expect.
If you are experiencing constant reboots on your mobile phone, try turning it off then open its back cover and then remove its battery for about 5 – 10 minutes.
This procedure will totally drain your phone from all the charges generated by the battery. Install the battery again after the time has elapsed and then see if this fixes the problem.
You may also consider restoring your phone to its factory settings. But be sure to completely backup your phone’s data before doing this because this procedure will completely wipe the phone and leaving it just like the first time you bought it. Just install all of your applications back after this.
