Recalling and rebuilding an email
Is it possible to recall an email after it has been read by the recipient? If yes then how you can recall it.
first I would like to clarify you that you and your beneficiaries are all on Microsoft Exchange, you can review the message (which intends to attempt to erase the message from the beneficiary’s Inbox) or supplant the message (which implies you need to erase the first message and supplant it with another one.)
No. Once an email is dispatched to the recipient, regardless of whether or not the recipient has read the email or now not, you can not remember it. This is just now not the way an e-mail works.
Once an email is delivered, the best manner, if you need to recall, is through sending any other electronic mail saying that you send the e-mail by using a mistake or for whatever motive you’ve got to your mind.
