Received the error message using MPlayer
Recently, I received the following error message using MPlayer. The error says that MPlayer crashed. The drivers are working properly. I reinstalled this player but the same message appeared. Is this any way to solve it? Provide me the solution. Thanks.
-MPlayer crashed. This shouldn’t happen.
It can be a bug in the MPlayer code_or_in your drivers_or_
In your
gcc version. If you think it’s MPlayer’s fault, please read
DOCS/HTML/en/bugreports.html and follow the instructions
There. We can’t and
won't help unless you provide this information when reporting a possible bug.
OK
