Received errors with pages that have a search button in Moss 2007
We received errors with pages that have a search button in Moss 2007. When the error occurs, we have to restart the ibis service to resolve it. This happens every day. Does the problem have something to do with the ibis service?
Best Answer by Whudson Audrey
Answered By 5 points N/A #105014
Try to scan your computer for possible viruses. Update to the latest version and check for damaged or corrupted files. Download an Error Repair Tool software. You can try the CCleaner as it can help you repair damaged or missing files.
And if the MOSS 2007 search button is showing, check on the server under the Central Administration Home Page if it is enabled.
Answered By 0 points N/A #197420
You just check your system possibly there is certainly a corrupted document, I do believe you need to believe it is available after which it clear up it. You'll be able to adhere to these kinds of methods presented below;
1. In the web page of one's top stage group site, select Generate through the Website Actions menu.
2. Decide on Web sites and Workspaces from the net Websites group.
3. Fill in the facts to your brand-new site. Make sure you select the Lookup Core web template beneath the Business bill.
Also it may be beneficial in order to inherit permissions of one's top stage site when you is likely to want to ensure many end users involving top stage site are able to gain access to this advanced lookup interface.
4. Click on the Generate key to complete this creation of one's brand-new lookup site.
5. You may be rerouted towards webpage of one's brand-new lookup site. The particular web site will probably be showing the lookup container with a link to this Superior Lookup web site.
6. Click on the Superior Lookup hyperlink.
7. In the Superior Lookup web site, duplicate this web site on the web site.
8. Decide on Website Controls through the Website Actions menu.
9. Since you also usually are over a sub site for a top stage site exactly where a lot of site collection controls are present, it is advisable to subsequently select Go to Best Degree Website Controls.
10. Decide on Lookup Controls.
11. Find the top choice and insert in the WEBSITE that you just replicated with action 7. The particular WEBSITE must stop using /the url name of your search site /advanced. Aspx.
12. Just click ALRIGHT.
13. Whenever you have resumed your home web site of one's group site, you might at this point see the Superior Lookup hyperlink and simply clicking it's going to provide towards the Superior Lookup web site.
Regards.
