Hi Experts,
Have a look at the error message. I received this message while forming a SharePoint Project in Microsoft Visual Studio 2012. I searched every possible source to get a remedy of this issue. But I failed. Do you have any idea of this issue?
Please help.
SharePoint not installed
A SharePoint server is not installed in this computer.Â
Received message while forming a SharePoint Project in Microsoft Visual Studio 2012
Hello Ammelia,
Make sure that you have done the following before you go on with forming the SharePoint project:
Ensure that you have reset the Internet Information Service (IIS) during the deployment step.
And then automatically associate workflows.
Also ensure that you have set the feature activation order according to the hierarchy in the Package Designer.
Carl
the screenshot you have given is not clear. it would much more better if you had attached the image with the attachment option.
if you contact with a Visual Basic expertise that will give you a result.
