I am receiving the blue screen as well as Fatal Exception Error 016F:BFF8CC32, when I am ready to restart Win98.
This delays me to install a number of software as well as programs properly, like my latest Verizon DSL software with printer software.
I need to solve this.
Please help me.
Receiving blue screen as well as Fatal Exception Error while restarting Win98
Hello Calvin ,
I can see you have a disk cache problem. Edit "System,ini" file and change it from "min & maxfilecache=32552" to "min & maxfilecache=8096".
If you are unable to find it then you should turn on the option to show hidden files and press F3 and search for it. That would do the trick .
But I Think you should get a newer version of windows.
Such as Windows XP or Windows 7.
Good day to you.
This error occurs because some important files from your computer was removed or corrupted.
Sometimes it occurs for computer virus. Take care of your operating system as well as your PC.
You can use Diagnose Blue Screen Error Repair Issues to solve your problem.
I think it will help you very much to solve your problem. Â Â
