Receiving error message attempting to set up Kaspersky Internet security
Hello
I am receiving this error message when I am attempting to set up kaspersky Internet security 2009. I need a solution of it. Help me.
Thanks in advance.
Hello
Thanks in advance.
Regarding this matter I would like to suggest that you have to download the latest version that is compatible to your computer operating system because compatibility reason is very important when downloading and installing a software. The latest version of the antivirus would probably solve your concern.
I hope this suggestion will help you a lot.
Hi Valerie Kely
I have also faces the same problem last week. This error is occurred because this key is used by too many user of Kaspersky.
I suggest you can try the any other key. Your problem may be resolve.
If you have still problem, then you can download the full version (With Product key) as well as trial version from the mentioned link:
https://usa.kaspersky.com/?form=1
I hope it will helpful. Thanks!
