Think you’re not running your Web browser and still receiving pop-up ads on your desktop. Yes you heard it right abrupt Pop-up ads are seeming on my desktop. This irritating pop up messages appears even when you surf and compute. The same happened with me. So how did I solve this issue?
Receiving Pop-up Ads On My Desktop
This occurs when one have most probably installed adware which is a program that shows unwelcome ads. Though munificent adware exists, most of the time adware is up to no good. After some study I found that I have downloaded a mass of little system-efficacy tools that assures to clean up the lot, with labels like PC Speed-up, PC Quickness Pro, PC Speedifier.
And from then I started escaping downloading programs that bid to speed up your PC or fresh up your archive. In its place, I use a reliable adware scanner like the free version of Malware bytes’ Anti-Malware tool. I just disabled my standard antivirus software beforehand running it. And thus this popping issue solved.
