Receiving Reply From Destination Host Unreachable; Connection Failure.
Asked By 5 points N/A Posted on -
I have been facing many problems with the remote host. There have been many instances of connection failure and many error messages have been received. Please tell me what needs to be done when I get reply from the destination host unreachable?
Answered By 10 points N/A #294247
If this message appears then there are possibilities of two errors. The first one is that there is no channel between the local system and the desired location. The second one is that remote router says that it has no proper channel to the destination. This is small issue and can be fixed soon. If the error says destination host unreachable then there is no channel from the local system. If the error says reply from IP address destination host unreachable, then there is a routing problem at the router end.
Image result for reply from destination host unreachable
