Receiving single message again and again
I have been in great trouble since yesterday that i startd receiving a single meesage from a friend again and again.Infact he assured me that he set it once.Why is this happening due to some network problem or my own mobile problem,currently I am using Nokia phone.Pls help
Best Answer by Pallasigue Stabins
Answered By 0 points N/A #127076
Hi
Anam
The problem might be because of many problems.
1#
This is not a phone issue. This is network issue. Ask your operator to disable the message service for a while. Wait for few hours. Then again request them to enable it. Restart your phone. Now see whether it works or not.
2#
Move your necessary files at secure place. Then format your phone. Now restart it and see whether it works or not.
Hope this helps.
Answered By 15 points N/A #127077
Hi.
It’s really not your phone issue. It’s a simple network error. All you need to do is simple reset your phone and if possible switch it on with different connection. Wait for some time and it will get fine again.
It’s not any issue or some virus.
