ariel chu
20 points
Posted on - 05/15/2012
Hi experts,
Recently, I detached a mounted software in my computer because I am experiencing problems with it. I remounted it but just worsen the dilemma. Every time I try to open the application, an error message looks like this appears:
ADF4150 – USB ERROR
ERROR 1001 – NO DEVICES FOUND
Can you assist me with this problem?
Thank you!
Recently detached software always pops-up error
Just install the correct driver for the software and then it works. And if that is not available then try o restore the state of the machine to a restore point found in Start à ALL Programs à Accessories à System Utility à Restore Computer. Here you shall find the restore point prior to the installation. Restore your system.
Another way-out is to rollback the previous driver through device manager. Open device manager from control panel and then you have to find the specific hardware that requires a driver. Right click and then roll back the driver. This helps to get to its previous form. The best way is get the driver.
