Recommend Ubuntu 8.10 or Fedora 10?
How would I recommend Ubuntu 8.10 or Fedora 10? Are they referring to a version that has good driver support?
Ok, I recommend you Ubuntu 8.10. Its interface is better than Fedora. I think Ubuntu have more user friendly Graphical User Interface (GUI) than Fedora. Again you will get almost every driver with Ubuntu. You can also get it with Fedora, it’s not a problem. The main difference is in GUI. Ubuntu comes with Gnome desktop environment. It’s nice to look at. You will find Ubuntu easier if you switch from Windows. Fedora is little bit complex in this case. Drivers are not a problem at all. Just go to “Additional Driver” option. You will find the option to downloaddriver. So try Ubuntu 8.10.
