Recommendation for upgrading NT to 2003
Everything is 2000 or 2003 member servers except for PDC and BDCs because these are NT, and I am upgrading it from NT to 2003.
Do I need to upgrade everything in my 2000/2003 member servers even if they are not in NT domain?
Best Answer by Bankk benediict
Answered By 0 points N/A #120485
To add to the above recommendations, you will need to note that, when  upgrading to Windows 2003, note something about its functional levels and Migrations Paths.
Note that, in the design of  a new Microsoft operating system, the compatibility issues of the legacy client are always considered.
Windows Server 2003 legacy includes Windows NT 4.0 and Windows 2000 Domain environments. Note that the functional level chosen typically states what type of functionality the Operating System is operating under.
Thank you.
Answered By 0 points N/A #120484
The 1st server you need to update could be the key domain controller (PDC) managing Windows NT four. 0 or maybe previously. In the update, the Powerful Listing Set up Wizard involves that will you may become a member of a pre-existing domain shrub or maybe natural environment or maybe make a brand-new domain shrub or maybe natural environment.
Before upgrading you should be sure that:
  • You are perhaps the Schema, Sector or maybe Venture Admins Group.
  • Your ADprep util is used, that is included with Service Load up 1 with regard to Windows 2003, this will let you any time upgrading the OS, the electric possesses greater exposure components that will assist the update get better also it displays incompatibilities that could be found.
  • In the event managing Windows 2000 the Administration application load up should be removed just before upgrading to be able to Windows 2003.
  • In case you are managing providers with regard to Unix variation 2. 0 update to be able to Services with regard to Unix variation 3. 0
  • In case you are managing Swap on your own Microsoft windows 2000 domain you should function the LDF for the Windows 2003 DVD known as Exchangefix. ldf. You can use this along with LDIFDE. This may resolve the schema glitches that were shaped because of the Swap 2000 FORESTPREP. Next application possesses function successfully afterward you will likely need to function FORESTPREP with Windows 2003.
  • Make sure DNS can be operating the right way knowing that other hosts may be gotten to from other identify.
  • In the event SBS 2000 can be installed the update course is merely available if your update is completed to be able to SBS 2003.
  • When setting up or maybe upgrading to be able to Windows 2003 be sure that the computer that you are setting up to be able to is just not condensed except if condensed employing Windows NTFS. Our professional recommendation is just not to setup upon any generate that is condensed.
