Recommendations on High Quality Headphones
I am planning to buy a headphone, I'm in doubt of buying the overpriced headphone (BEATS by Dr. Dre Pro). Any suggestions for better headphones?
I recommend Sony MDR-XB300 Head phone. 30mm driver, 5-22,000Hz frequency response and 100dB sensitivity. Best performances and Cheap prize as $50. Most of friends using this, No problem and buy it.
Hello Alex
From your post, I understand that you are not looking for normal Headphones. You want quality but at a decent price. Several manufacturers provide it but you need to make a decision based on your needs and requirements, not to forget the budget too.
Below I will recommend the best Headphone that I know, and I consider to be at a decent price. Click on the link provided if you want to see more details about the product.
I hope you will find this information useful.
Randolph
