Record adding problem on QuickBooks.
This feature is not enabled or not available in this version of QuickBooks.
am getting this exception when I adding the record to the quick book so please give me solution to it
Thanks .
Thanks .
This is a type of a bug in the version you are using. It was only causing problems to the US 2008 users and has been fixed in the later versions. The main reason for this error is disabling of Unit of measures. You can follow any of these solutions;
Solution 1: Update to version 2.143 or later one. Click on About/Register and then check for updates.
Solution 2: Try rebuilding your data file (File > Utilities > Rebuild data) this will immediately sole your issue.
