Record Level Data in CSV
I just need to learn and record the compatible level data of Comma Separated Values (CSV). For example, if I will get a flat data format, through this 1'SQL', 'ABC' 2 'SQL', 'DEF' 3 'PP', 'BGC'. Through this, I have to learn this PL a kind of files. If PL type as "ABC' then I'm doing any processing and writing 'PL', registration as well. After RIC in writing the record pointer will be given at the end of file, but for the second reading of my guide must be 'DEF'. How I can set my guide on 2 different levels in the same flat data to read and write? Any suggestions? Thank you.
Answered By 10 points N/A #91198
You do that by doing the following:
  • In the excel file, you will just go to the file option
  • And then choose page layout option.
From the window that will open, you can find options that will enable you to preview the parent record file only, or you might as well choose to view only the first record. When you do it that way, you will not need to be worried about writing the code so that you can be able to copy the record file that you want and execute it.
You can use the same procedure for two or more levels of data as you like, it will save you the trouble  or going to back end to modify the code for the records to run.
Regards
Thonpson Locker
