Recording device does not support the selected audio sample rate
Hello Grace,
Well in your case. I do suggest that you go to your MAGIC Movie Edit Pro and find the settings or configuration of the program, set the following audio sample rate to 96000[hz] as what the error message conveys. But if you cannot find 96000[hz] in the software, there must be a compatibility problem. The audio sample rate is not supported by the magic movie edit pro software. Try to install a latest version with all the compatibility measures including the audio sample rate that supports 96000[hz] to avoid interruptions with your recording. One thing, you should be aware of the software and operating system compatibility to avoid errors.
