Recording from Cassette to pc
Is there any software which helps to record your audio from cassette to pc. Are these types of software is of free of cost or you have to buy?
Yes you can record cassette to pc. There are two ways to deal with digitizing tape tapes. The first is to purchase a tape player or blend media player that incorporates a CD copier or USB sound card with programming for recording to a PC.
The subsequent methodology is to join a current tape player with a USB, Thunderbolt, or Firewire (contingent upon your PC’s I/O) sound interface or with a computerized field recorder that acknowledges the simple line-level yield of your tape player.
By purchasing some sort of software that is the best these days. You just have to spend very less amount and your work can be accomplished but the best one among them is AUDACITY; which has also free versions available.
