Recording TV program in Computer
I have an External TV Card connected with my computer.
How can I record any program from TV to my computer when I watch TV?
Hi there ,
It seems you are having trouble recording your Live TV on your pc using the TV tuner card.
There will be a CD accompanied with your TV tuner card , Make sure you install the software's in that .
I'm most cases the TV tuner card manufacturer will give you the Recording software included in the software package.
If not then find out your TV tuner card model number . Copy paste the manufacturer and model number in Google and Add download recording software for to it .
For eg :-
If your card manufacturer is QWERTY and model number is TV5564 then type the following in Google : –
Then find the best match and then download it and install it.
Good luck.
Notifications
