marie marie
Posted on - 02/01/2013
Is there any recovery software that will recover the file with any particular size that is given as input to it. Example: Enter to recover 110 MB file after format, it will recover all the 110 MB files from the formatted disk. Is there any such software, if so please convey.
Recover 110 MB file after format
You can recover the permanently deleted files from your computer by some recovery software. Deleted files often present in the hard drive unless they are replaced by other files.
The sooner you will take action the chance would be more. Best free file recovery software is Recuba, Softperfect File Recovery, Restore etc.
Hi. Marie,
You can solve your problem if you find software that will recover the file with any particular size that is given as input to it.
So here is a solution for the problem you have to choose and install 1 among from Recuva, Glary Undelete, Pandora Recovery, Soft Perfect File Recovery, Restoration, Avira UnErase Personal, FreeUndelete or ADRC Data Recovery Tools. Just type name of 1 in Google and you can get the number of websites to get a free download.
I hope that this will fix your problem.
Thanks & Regards,
Gillam Janetj
There happen to be a lot of data recovery software out there, both paid and free ones. Below are some that are not for free and are highly ranked when it comes to data recovery.
Virtual Lab Data Recovery, File Scavenger – Data Recovery Utility, Boot Suite 2012, Recover My Files and Kernel Data Recovery. You can use them to find deleted files then choose the size of data or the specific file you want to restore.
