Recover from blinking cursor Windows XP boot problem
Use Windows 7 DVD
You can use the Windows 7 DVD to repair these black screen issues in the system. For this, you need to insert the DVD in the system and then restart the system. You will be then prompted to press any key to boot from the disk. After pressing any key, you will reach the “Install Now” screen. In this screen, you need to select the ‘Repair Your Computer’ options. In the next screen appearing, you will get two options from which you need to select the first option and then select the OS you installed in the system. Choose ‘Start-Up Repair’ from multiple repair options. You will get the system restarting itself and you can get the issue resolved with this.
Last known good configuration
It is possible that any serious changes to the Windows 7 system get it in black screen error with the cursor hang. You can try restoring the system to its last known good configuration to resolve the issue. For this, you need to tap specific keys to enter the set-up of the system. As the BIOS appear, search out the Restore Default Settings options. After selecting the option, save it and then exit the menu. You will then get the system to its initial state. You will get a boot options menu as your computer restarts and you need to select the ‘Last known good configuration’ from this.
Disconnect any external devices
If still you experience the black screen issue in Windows 7 system, you can check if any of system hardware is causing the issue. For this, you need to remove each external device of the system and try to start up the system. You may try disconnecting any unwanted internal devices to fix the issue.
The problem means your boot process hangs up. To proceed with the fix of this issue you must try first by running your operating system under safe mode. When running in safe mode, the operating system ignores running services and other accessories that runs in your computer during boot-up. If you are able to run your operating system in safe mode, your lucky. Inside the safe mode run the cmd.exe and type “chkdsk /f” in your command prompt to run or schedule check disk on start-up to fix errors so that you can boot on normal mode.
If the above option could not be possible, run your system repair disk by booting-up using the original windows XP installation disk then choose repair on the option when prompted. On the prompt, type “chkdsk/f” then reboots.
If still can solve by this option, re-install your operating system.
If re-installation is not the solution, your hard disk drive might be damaged.
