Recover corrupted memory card data
My memory card is corrupted, so now I am in a tension. How can I recover it?
Because many valuable data is located that’s drive. My MMC drive properties show the actual size on disk. So I am sure I can be recovering.
How can I recover my data
But I don’t know these tricks. Please give me a better answer.
Best Answer by sambota
Answered By 0 points N/A #118167
In covering your lost data in your memory card, try visiting http://download.cnet.com/Data-Recovery/3000-2094_4-10664893.html and download  data recovery. Select the program that suited your PC and make sure it’s compatible and easy to use software. Once you have downloaded it, install the software and run, you may also need a memory stick or a USB Flash drive, analyze your software and the program. That’s it.
Answered By 0 points N/A #118169
Good day Tyrone,
Your question is regarding your corrupted Memory Card and your lost data which you want to recover now. You have mentioned that your memory card properties showing the space covered by the data, which seems lost. Now what you have to do is follow a few simple steps.
Download “Recuva”, free software that is used to recover lost files. Install the software and through it recover all your data. Keep in mind if you will try to recover your data again and again, it would be lost for good or it would be corrupted and would not work even though if it have been recovered. So be accurate while recovering data using the software.
Thank you.
