Recover Data From External Drive
Accidentally I formatted my Hard Disk which contained some required data, and now I am in need of it. Can someone help me to Recover Data from External Drive?
You can perform the following for recovering the Data From external Drive. Use the EaseUS software to get the data backfrom External drive, and for this action, you can click here to download the software.
If you don’t find your required file, then click on deep scan.
Recovering an accidentally formatted partition shouldn’t be a problem but successful recovery of the partition doesn’t guarantee that all files are 100 percent error free. To have a high chance of recovering your files, don’t touch the partition like don’t put or copy any files into it. Download and install EASEUS Partition Master Home Edition. It is a hard drive partitioning software that can recover lost partition.
It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 including Windows Server 2003, Windows Server 2008, and Windows Server 2012. The application allows you to resize or move a partition, extend your system drive or partition, copy a disk or partition, merge or combine partitions, split a partition, redistribute free space, convert a dynamic disk, and most importantly recover a partition.
You can also download it from its EaseUS Official Home Page. The free version can support up to 8 TB hard drive capacity. If your hard drive is bigger than that, you probably need the Professional version. The Pro and Server editions can support up to 16 TB hard drive capacity.
Notifications
