Is there any way to recover important emails that are mistakenly deleted from your mailbox or inbox. If yes then how you can recover them? Answer in the step by step form
Recover emails from Outlook 2010
For recovering you has to follow certain steps:
- Open the Deleted Items folder in your Outlook Account.
- Then Make a Right-Click on the Email which you need to recover.
- Point the Cursor on Move option.
- Select the folder where you need to keep the recovered email.
- Recover Emails from Deleted Items Folder
This technique will simplest be relevant inside the case of the temporary deletion of Outlook emails. If you have eliminated emails from the Deleted Items folder then you should observe the next approach to restore the erased emails.
