I have two Facebook accounts. I think I accidentally deleted one account from my phone when I clicked “Sync” on my phone. After that I couldn't access the other account. please explain to me step by step because am kind of desperate. Does anyone know how to resolve this problem?
Recover Facebook account that was deleted by mobile phone
Hi!
Here I provide two solutions according your different situations.
If you deleted your Facebook account temporarily, you should try to log in back your Facebook account. Then, your Facebook account will return to normal condition back.
Otherwise, if you deleted your Facebook account permanently, you should not wait longer than two weeks for you to log in. If not, you have no chance to retrieve back your Facebook account.
There's a difference b/w deleting your account and deactivating. If account is deleted, then you can't get back to your account. To recover your deactivated facebook account you just need to follow these simple steps:
1) Login to your facebook account with the same login details.
2) You will see a disabled account warning and some confirmation details.
3) Just confirm the account and re-enable it.
Hope this helps
Try to login your account from your PC. But if you have deleted your account than unfortunately you are not able to access it again and it is not possible to regain access to your account again. On deleting your account some of the private credentials are deleted form the databases of the servers which results in loss of the data associated to your account.
Hello Moses,
Go this Techyv page "How to recover FaceBook messages". This Techyv also will be helpful for you.
