I have been facing a problem with opening an excel file. Actually I am using office 2000 on Windows XP. And I have an excel file containing a very important data related to my personal income and expenses for the year. But the file no more opens. Unfortunately, I didn’t save the file anywhere else.
Please help me out in resolving this issue so that I could recover my important data and save it somewhere. Please help me out in this matter.
rbaculi
Recovering data from Ms Excel
You could try to use some tools/programs e.g. Advanced Excel Repair AER to repair this document.
AER is powerful to repair damaged or corrupt MSExcel files.
For details, please visit the Advanced Excel Repair – Repair corrupt Excel files.
Fix Excel files. Or you can obtain some information and download demo version
Thank you for your attention.
If you are not able to open your file at your computer then you can open it over the network and that will see the data of your file if the file is not being corrupted. If you have updated your system in previous days and now you have another version of office then you can simply see your file online. You can also convert your file from one format to another format. It is easy also to convert your file form office 2007 to office 2011.
You can do this online and you will be able to see your file. If your file is being corrupted and is not able to see then you can use recovery tools such as recovery point or file recovery system. In case you can not do these all then you need to put your file online and this will automatically open your file with a right format.
Here I am attaching a link that will take you to your desired website on which you can open your file.
You can open and recover the corrupted Excel data by following methods.
1. The document of recovered copy is opened.
2. Choose command Open and Repair.
3. Save in format of HTML.
4. Save in format of XML Spreadsheet.
5. Use Macro to extract any data when the chart is related to that corrupted file.
Hope this helps.
