Recovering a deleted file on USB
Is there a possible way that I can recover my file that has been deleted on my USB device? Thank you in advance.
Files that were deleted from USB Flash Drive do not have the chance to go to recycle bin where we can undo them, unlike with computers. Nevertheless, because of our high-technology now-a-days, we can still retrieve those files back even though they were deleted from the USB Flash Drive. However, you’ll have to act fast and make sure you do not write anything else on that flash drive yet:
First of all, do not try to modify anything on the USB disk that you are trying to recover. Do not save or delete anything so we can avoid on overwriting the old files that you need to recover. Then download the Recuva software from the link below:
Download and Install Piriform Recuva Software
After downloading, install it on your computer. Follow the on-screen instructions to search for your USB drive where the files that you wish to recover was stored before it was deleted. It will take some time but just let it run.
When Recuva is done on scanning your drive, it will show you a list of files. Just select which files you want to recover and click the Recover button.
