Recovering invisible files in flashdrive
I have a 4GB RIDATA Flashdrive that I always use. Earlier I checked its size and it's just weird that even I only have small TXT files on it, my free space is only around 400MB. How can I see those hidden files that don't appear even I already ticked the show hidden files on my folder options?
Answered By 5 points N/A #119592
Hidden files without your knowledge is common nowadays. If even you enable the option “show hidden files” still you cannot see the file or files its because of the Malware infection and you do not have to worry because you can easily recover the hidden files by connecting your flash drive to a computer that has an up-to-date antivirus installed or you can use the freeware USB Show software. Just download, unzip and run the software. Attached is the picture of the USB Show software.
You can use the freeware USB Show software. Just download, unzip and run the program. Click on ‘Recovery the hide files’ button and select your USB drive. This should help you. I hope I did solve your query.
Teodora Skil
