xseriez
Posted on - 06/21/2012
Hi, How do i recover some files that i accidentally deleted from my PC.
I had done a backup of my phone contacts in my laptop and i formatted the drive.
I have partitioned my laptop. drive C and D.
Is there a solution?
Recovery of deleted files on windows
Dear Xseriex, your concern of deleting you contact information/data can be addressed in the several ways even if you accidentally delete them from recycle bin or formatted you laptop as you have said.
What you need to know is that there is a high chance the information/ data you deleted is still on the computer system and they can be recovered.
You will use undeleted software known as i recover, this software recovers deleted files.
 If you cannot get it on the open market you can take it to data recovery specialist pay few dollars to help you to recover your data ,alternatively you can buy the irecover software not less than $40.With the use of the guideline am sure you will easily install it.
i recover is good software that can help you recover the files that are deleted from recycle bin, corrupted system, formatted, deleted partitioned cases like yours, errors and data damaged by virus.
Use this link down i recover.
It is always important to keep backups on your hard drive if possible every month, though personally l would recommend a weekly. Use genie Backup Manager will help you to store your data safe.
For your information there was lots of data recovery software that you can use to recover easily the lost file. Like Panda Recovery, TOKIWA DataRecovery, Undelete Plus, Recuva, Advanced File Recovery, Windows 7 data recovery software and more. Almost all data recovery software could manage to recover files even if you deleted the files from Recycle Bin, or even from the formatted partition, the partition lost, partition became RAW, partition cannot be accessed, etc.
Once you delete a file the data won’t be erased immediately. Windows will mark the space in your hard drive available for use because it considers that the file that you deleted is unused but it is still there. So, If possible you have to act right away to start the undelete process for you to recover the file before Windows overwrites that said available space in your hard disk for a new file. Take note that when it happens you deleted a file, avoid not to save any new files or data temporarily to the device concerned.Â
Not even downloading a recovery software because it will take a lot of space in your hard disk and most likely will overwrite the space of the deleted files. You may use a memory card or an usb for this matter.
Dear Xseriez,
There are so much complications in recovering files when deleted. But this is not an impossible task to perform.
There are many methods to recover files that have been deleted.
Many software are available in the market that can recover your files very easily.
I suggest you to use a best software "Easeus Data Recovery" in this situation.
You can download this software from this link.
Hope it will help.
Thanks
