I need to repair corrupt rar files. I need the greatest repair rar tool for that. Does anyone have any experience in Recovery Toolbox for RAR program?I have heard that it is an easy problem, but is it easy too? Is there any other program to repair corrupt rar files?
Is the Recovery Toolbox for RAR the greatest repair rar tool?
Hello, Robert L. Mathis!
Recovery toolbox for RAR is an easy to use program. With it you can almost always fix RAR problems. Program is specially good with fixing, when archive is in unknown format or damaged, when CRC check fail or with unexpected end of file.
When I had some problems, I always solved them with this program. But there are also other programs, of course. On the market there are RAR repair tool, advanced RAR repair, etc.
I would recommend you to try them only if you will not manage to fix your problem with recovery toolbox.
Best regards, Denis
lee hung
75 points
Robert,
Recovery toolbox for RAR is very easy to use, here is a website that you can use to download a version of it: http://download.cnet.com/Recovery-Toolbox-for-RAR/3000-2250_4-10666647.html. The first thing you will have to do is choose the correct download, based off of the version of Windows you are using. The download will walk you through the installation and then just open the program when its done, click on "Start>Programs" and you are ready to get started.
