Recovery toshiba l505d to factory condition
Recovery Toshiba l505d to factory condition with holding down the 0 key or F8 is possible? But what to do if this doesn't work and if you don't have recovery disks?
Hi
That's really a terrible situation since pressing 0 key or the F8 key is required to be pressed and is mandatory if you do not have the hard disk with you. There is no way now to restore the Toshiba laptop to factory condition since you don't have the hard disk as well as 0 key and the F8 key is not working as well. The best way now is certainly to get your laptop repaired from a hardware engineer or you can contact the customer care of Toshiba for further assistance.
Watners Magner
