Recuva- A Recovery Software For Deleted Files
I was using my laptop, and I accidentally deleted my father’s important documents even from the recycle bin. It was very important to him. Could you help in restoring those documents?
This thing can happen very normally. So to recover those files that were deleted, there are many recovery software on the Internet. One of them is Recuva software. It is free and easy to use. You can download it from here and then use it to recover all your deleted documents, private photos, videos, etc.
If you need to undelete or restore deleted files even when they are deleted from the Recycle Bin, try downloading PC Tools Performance Toolkit and install. Once installed, start PC Tools then go to “Recovery” tab and click “Recover Lost Files.” Try selecting “Deep Scan” or “Physical Scan” in the “Scan type” option then select the drive you want to scan.
Click “Start Scan” to begin analyzing your hard drive. If the files you want to restore are located on the system drive originally or drive C, recovery is not guaranteed because continuous file activities are happening on the system drive. To successfully recover a deleted file, the drive where it is located must not have any “write” activity like copying or moving of files.
This is because the sectors the deleted file originally occupies can get overwritten with new data. Also, even if you managed to recover a deleted file, the content of the file is not guaranteed to be one hundred percent (100%) error free. Most of the time, the content is garbage.
