Am kind of worried because my favorite game is having problems. This is the Red Alert 2 game. It displays an internal error and cannot continue normally. What can I do about this? I tried to reinstall it but no success yet.
Red Alert 2
Red Alert 2 has encountered an internal error and is Unable to continue normally.
Please visit our website at http://www.westwood.com for the latest updates and technical support.
Red Alert shows severe error
Hi Gene
First thing to do is turn off the windows firewall.
To do that click Start/control panel/Network and Internet connections/change windows firewall security settings/Off (not recommend).This should work.
points
Hello Gene,
Try RA2 Patch 1.006. This will fix the game files. Copy the file into the installation directory. I mean, the path where you installed the game. Then, run the patch file.
Also, uninstall the game completely. Then re-install the game.
This should solve the problem with the launcher.
