Red pocket Mobile App for Google
Hello Ms. Ashley. Bila, You will have to manually download Red Pocket for ice cream sandwich only because Google does not allow 3 party apps from producing APN settings modifications with this version from Android, but you can follow the manual configuration instructions to do so.
Red Pocket states it will have an updated version of Red Pocket fro Android app as soon as a workaround or a solution come available from Google. Here is a link to do.
Hope this helps out.
Since Red Pocket Configurator doesn’t work on any Ice Cream Sandwich Android Smartphones, here is a solution on how to do the trick of making the application to still work on ICS Smartphones.
You need to do a lot of editing on your Android Smartphone to make Red Pocket Configurator work.
For the Data and MMS settings:
You should also check and make sure that the Use Packet Data option is checked under Mobile Networks, and Data Roaming should be disabled or unchecked.
For Samsung Smartphone users:
For those users using HTC, Motorola, and LG Smartphones, please visit Knowledgebase: Configure – Ice Cream Sandwich for the rest of the guide.
Notifications
