RedCrab – The Calculator 4.14
The newly arrived RedCrab – The Calculator 4.14 is very helpful for the science students. Can interpolation be done with it?
Hi Isabellagregorey,
RedCrab is a scientific calculator with a full-screen editor.  As I saw interpolation can’t be done using it.
It is supports the entry of complex algebraic equations with fractions, square roots, exponents, etc. for technical and scientific applications.
The mathematical expressions are not typed in a typical command line, but can be enter in the editor window. It is display the result either under or next to the expression. The handling is easier than conventional calculators.
Several mathematical functions can be written on the same page. Results from one expression can be carried over to the next task.
You can save and load the formulas to create a formula library.
Complex tasks can be explained visually by importing drawings in bitmap format.
hi!
if you are looking for an Interpolation calculator , you can try AJ Linear Interpolation, It is used to solve linear interpolation.There is some inline calculator are also available to do such calculations.
e.g:
https://www.easycalculation.com/analytical/linear-interpolation.php
https://www.ajdesigner.com/phpinterpolation/linear_interpolation_equation.php
