Redirection from www yahoo fr mail
After Coming from France my Laptop always redirecting to www yahoo fr mail where I am in UK. Please provide me the resolution.
Good day, one thing why Yahoo redirects is because it detects your IP. So probably when you went to France, it detected the IP address of the connection you are using.Â
Now, to stop Yahoo from redirecting to yahoofr, please check your browser if it is set to "enable cookies." If not, please enable it.Â
Another solution is for you to change the location in your desktop and time zone, try restarting your computer and browse the web.Â
If it still redirects, you'll have to type in manually the website you want to visit.Â
For example: us.yahoomail.com instead of yahoomail.com
Many thanks!
Good day Susan,
Here's the most effective way to do this:
1.  Sign in to your Yahoo.
2.  Go to your Home Page.
3.  Below the Home Menu you should see a submenu link called "Yahoo Site" then click the gear icon beside it that says edit.
4.  Click the "Yahoo International" menu link.
5.  Choose the country you want to add and click the plus icons link  beside it .
6.  Click "Im Done" below.
7.  Below the "Home" menu bar  the country site you add on should appear as a link.
You should now have direct access to your country laboriously tweaking your computer system.
Hope this helps you.
