Reference line missing in Sent mail
Outlook 2007: When I look at “Sent Mail” there is no column for the subject matter…how do I correct this?
This is happening because your Sent Items folder is configured like that. You can add Subject column manually in order to view that.
Please do the following steps.
1. Select View-> Arrange By-> Custom…-> button Fields
2. Here you can select the required fields.
3. On the left list select "Subject" and press Add.
You have nothing to worry at all. In order to get your problem solved you just have to customize the appearance of your mailbox. Do the following for this purpose;
· Sign in to your mailbox.
· Under general settings tab, choose appearance.
· Here drag “Subject” from Available Columns and drop to Columns to displayed.
· Click Save.
Notifications
