Regarding Google pop ups blocking
I have installed a Google pop up blocker. It always blocks the pop ups from unknown websites and ask me to allow them or not. It is good for avoiding pop ups But now I want to turn it off. My problem is that I don’t know it does not work rather blocks it. What can I do with it?
Best Answer by KenRichards
Answered By 0 points N/A #113126
From what I understand you wish to unblock these pop ups that your Google pop up blocker is blocking.  You can either uninstall the pop up blocker or you can add the safe websites to the pop up blocker so they are permitted.  When you click on more you should be able to customize the toolbar so that you can add safe sites.  Any pop ups from these sites will be permitted but pop ups from others will still be blocked.  To uninstall go to your control panel – uninstall programs – and from the list find your Google pop up blocker and uninstall.
Answered By 0 points N/A #113127
To solve your problem you can go through these steps and i am sure you will able to solve your problem.
First go to start and then to Control panel.
Switch to classic view.
Then go to internet options.
In inter net options go to privacy tab.
Here you will see the pop up blocker option just un check it to disable pop up in your browser.
Also go to settings and set all the websites there you want not to show pop up message.
Once done restart your browser and then reopen it and your problem is solved.
