Regarding real samples of point of sales using vb6 required
I am a new user. Therefore I lack so many things. I want to have seen some real samples of point of sales using vb6. How far is it effective ?
I see that you are a new user and want some real samples of point of sales using vb6. As you are a leaner, i suggest you to try the code on your. If you are not able to complete it there is n problem because you are just a learner.
There are many vendors who can sell you the code but it is better that you try it on your own first.
One useful tool for point of sales is the pos and inventory system. You can download it here — https://www.sourcecodester.com/visual-basic/point-sale-software.html.
This tool helps you in the point of sales and also to maintain inventory records. See the screenshot below:
You can also get the code from the website mentioned above.
Another alternative solution to visit this website – https://www.daniweb.com/programming/software-development/threads/352766/pos-code-in-visual-basic. It has sample codes that you can edit to create your own code according to your needs.
Hope this information helps you.
