Regedit.exe – Application Error in Windows 7
Guys need your help,
I try to open/run/execute regedit.exe, under Windows7 but when I try to move it I got the error message saying Regedit.exe – Application Error. I tried to rename it on .com and *.exe it works fine. That's the only error, and I don't know whay.Please provide some solution about it.
See image below:
The application failed to initialize properly (0xc0000005). Click on OK to terminate the application.
        OK
Thanks!
Best Answer by jimke
Answered By 0 points N/A #127529
Hi there
you don't need to rename the file
you can solve this issue by using below steps
all you need to have administrator privileges / user rights in the computer
go to run / searchbox and type cmd ( command prompt )
then Type  SFC /scannow in cmd screen
It will able to fix your error
thanks
Answered By 10 points N/A #127530
Run System File Checker ….
Start > Run > sfc /scannow – note the space and have your XP CD handy.
SFC will run and exit without any closing dialog.
To see which files, if any, have been replaced look in Event Viewer.
Answered By 590495 points N/A #316474
If you want to use or run the Windows registry editor or regedit, please remember that you can only use it if you have an administrator account. Limited or non-admin accounts are not allowed to use the program to edit the Windows registry. If you are using a non-admin account, shift to another user account with administrative privileges so you can use the registry editor freely.
If you don’t have an administrator account, you cannot use the registry editor. “regedit” or the Windows Registry Editor is a graphical tool in Microsoft Windows that allows authorized users to view the Windows registry and make changes. Note: only advanced users should work with the Windows registry editor and admins should always create a backup of the registry before making some changes.
If you made an incorrect modification, the computer’s operating system may stop functioning. The good thing is that, the Windows registry rarely needs editing. But sometimes there are problems where administrators have to make adjustments to the registry to be able to import or export .reg files or delete, create, or make changes to corrupt registry keys and subkeys.
