Registering PowerBook G-4 into a Windows 2000 domain
Hello
I have an original Power Book G4 running Panther. To register into a Windows 2000 domain, I want to set up Active Directory. I have put the forest, domain and ID okay, and then chose 'bind'.
At first it requests:
'Network Administrator Required'
Then it gets to '3 of 5: Verifying credentials' and asks:
'Authenticate', 'Directory access requires that you type your password.'
It finds to step 5 of 5 and then pops up a new window which displays "Insufficient Privileges" with "The administrator account you specified does not have the appropriate privileges to perform the requested operation."
Is this indicating to the 'Network Administrator' / 'Authenticate'? Also I have been trying all kinds of login for both, as well as admin with source user on the 'Authenticate' step and the sysadmin here went at the 'Network Administrator' login. It always shows the same error message.
Please help. Thanks.
