Hi! I just want to make sure of this. If I click OK, would it fix everything?
I always have errors to be fixed every time I run this.
Can anyone give me tips to prevent having so much error and what are the causes?
Critical errors found
RegistryCleanerXP found 43 critical errors on your PC.
Thanks,
Joep
Registry Cleaner XP concerns. How to prevent having so much error.
Yes, clicking OK will fix those errors. To prevent having a lot of errors in the future, make sure you install and uninstall programs properly. It would also be best if you can avoid downloading files from suspicious websites. You should also avoid opening links that you are not sure if safe (like free ads and email attachments from unknown people).
I hope this answered your question. Good luck!
Hi
Many reasons related with this and lot of registry cleaning software Create more errors and they push user to purchase their premium items. So don’t worry. I recommend Clean MyPc Registry cleaner and just try. You can reduce those errors. Don’t remove programs directly and try to use Uninstaller and keep your antivirus alive. Clean unwanted files and keep your computer clean.
