I have downloaded Registry Cleaner for my Windows XP but when I attempted to scan & Fix Registry an error message displayed during the cleaning process. How can I avoid these errors?
I really need your assistance to fix this immediately.
Any help would be appreciated.
Thanks in advance.
RegistryCleanerXP found 43 critical errors on your PC>
Click the "Fix Error" button to repair these errors.
Registry Cleaner XP critical error
Hello Arthur
First of all Uninstall the software (Control Panel -> Uninstall a program) and then access the link I have provided you with and download the latest version.
Registry Cleaner
Before installing it, please run a full scan with your antivirus to see if he finds something damaged or broken. Install the latest version of Registry Cleaner, and disable your antivirus while you scan with it.
I hope you will find this information useful.
Randolph
