Hi All,
I am using Windows XP in my office system, I am planning to have registry power cleaner programs in all my office system. I need to get a solution from frequent crashes by fixing registry problems and speed up all my systems. Please suggest me a program that can fix errors and stabilizes the PC.
Jerome C Carignan
Registry power cleaner programs for Windows XP
Hi there,
PC Registry cleaners are really necessary in offices because the users don't care much about the PC. One of the best registry power cleaner is McAfee Registry power cleaner. I recommend this to use in offices. But if you are willing to go for free third party apps then you can use "Pc Error Repair".
I hope my solution helps you in every possible way.
Hi Jerome,
There are 2 software that I can recommend you to use namely: CCleaner and Advanced System Care Pro. These 2 powerful windows utility provides you the functionality and features for ensuring the stability of the computer.
Functional and Powerful CCleaner – This software is a user friendly and effective system cleaner that can deeply scan and clean system files in the computer that includes cookies, history, cache, temporary files, utilities, applications and windows log files. It also has a functionality wherein you can scan registry related issues and fix it afterwards.
Reliable Advanced System Care Pro – This software is a all-in-one package software that can do multiple tasks into the computer system. It can defrag the hard disk, delete empty and temporary files, locate and remove malware and a whole lot more.
Ware
