Registry value is not found
I’ve installed Windows 7 x64 in my computer system. Further, I’ve also installed 32-bit LabVIEW. But when I step to start it as an Administrator it pops up with an error message “Error-603” saying that registry values is not found.
I’m only able to read HKEY_LOCAL_MACHINE values for HARDWARE AND SECURITY but not for HKEY_LOCAL_MACHINE/SOFTWARE.
Apart from this when I am trying to add values to HKEY_LOCAL_MACHINE/SOFTWARE path, it doesn’t get changed.
I will appreciate you if you help me in finding out the right answer.
Error:
Error -603 occurred at Read Registry Value STR.vi Possible reason(s):LabVIEW:Specified key or value does not exist.
