Lidia Hugs
Posted on - 10/09/2011
I use Microsoft Outlook 2007 as email client. Unfortunately,when I installed add-on in Outlook the following error message was appeared. I talked with one of my friend and he told me that it is the conflict between and outlook and Windows registry server. Is it true and what is the solution?
RegSvr32
DllRegisterServer in 08comps.dll failed.
Return code was: 0x80070006
Thanks,
Lidia
RegSvr32: DllRegisterServer in 08comps.dll failed.
We can resolve this problem with the help of installing the new version of MSVB VM50.DLL. Here I tell you all the procedure about installing this new version.
First of all download the latest version of MSVBM50.DLL from the internet that should be the newer version.
After installing the new version of the MSVBM50.DLL then install then software.
This software is use to ActiveX.dll file.
The version MSVBM50.DLL has the qualities in it like it is with Visual Studio 97 in service pack 2 or service pack 3.
After installing the software then restart your computer.
After restarting the computer, the problem will be successfully solve and there are no more issue about ActiveX.dll by using Regsvr.32
Hope so this procedure should help you in resolving your problem.
Thanks
